Configure DHCP Custom Options
The following table defines parameters for the ip dhcp-server command.
| Variable | Definition |
| custom-option-data <224-254> value WORD<0-128> |
Assigns a data value to a DHCP Custom Option that you defined previously.
| custom-option-def <224-254> type <ipv4-address | uint32 | string> [name WORD<0-128>] |
Defines the format of a customized option that you want the DHCP Server to provide to clients.
